I'm using an UltraWeekView to show AllDayEvents. At one day, there are to much Appointments, the MoreActivityIndicator is shown.
How can i show all Appointments of the day?
I am just checking about the progress of this issue. Let me know If you need any further assistance on this issue?
You should make your component bigger in order to be able to display more appointments. Other think that you could try is to review the following link where similar questions was discussed some time ago:
http://ko.infragistics.com/community/forums/t/65954.aspx
I hope that this will helps you.
