Good day,
I was able to save the data to database successfully using databinding, I tried to fill up the task name with TaskName1, TaskName2, TaskName3, and so on, now when I retrieved it back, instead of TaskName1...2...3, it is now displaying in different order. How will I change it and use the original task order as were created.
Yes, I was able to solve the problem thank you very much, and I am sorry for the late reply I was not able to get online lately.
Hello LSG,
Have you been able to resolve your issue ? Did you have a time to take a look at my suggestion ?If you still have any concerns or questions I will be glad to help. If you need any additional assistance don’t hesitate to ask.
Regards
The last part
Here is the second part of our video file
There are different approaches to solve this task. One possible solution could be :
Usualy your column TaskId is uniqueidentifier in your database. Also this column is Primary Key, that`s why by default your Tasks are sorted by the task`s Guid. You could add a new column into your database (in my sample I call this addtional column - "ID") The dataType of this column could be Integer or DataTime and so on. If you choose to be Intger you could set "Identity Increment" and "Identity Seed" properties of our new column "ID". By this way each new Task will get new id depending of your creation order. We will use this column to sort our DataSet by this Id. If you are using TableAdapters into your scenario, you could modify your Select command (in the TableAdapter) using "Order By ID" column. Please take a look at the attached video file for more details.
