435
Tab Control with Wizard Style and an applied StyleManager is showing tabs
I've recently looked at your UltraWinExplorerBar Basic Features sample and like the StyleManager your sample uses so I applied it to an application I'm working on. However after I added an UltraWinTabControl and set the style to Wizard I noticed the tabs are showing.  The tabs should not be showing when the UltraWinTabControl style is set to Wizard.  I'm thinking this is a bug?  If not what can I do in the style library to keep the styles, but not display the tabs when the tab control style is set to wizard?  Thank you in advance for your help.
