I have a problem that my C# form takes a while(around 1 minute) to open when I use and Infragistics components v8.1 (even if I just create just a normal Infragistics button on the form). After the form was loaded and you close it and reopens it, it is quick to load the form and create the components. If you leave the form closed for a while (5min and more) I get the same slow loading and creating of the form. All the assemblies used are added to the GAC.
Any advice on how to ovecome this slow loading process?
Thank you.
Thanks for the info clm_quintin!
I'm going to try solution #3 above since #1 and #2 didn't work for me. Do you know which .clr file in clr.verisign.com I should install? There're so many of them.
Thanks!
Hi James,
With the release of NetAdvantage for .NET 2007 Volume 1 CLR 2.0, Infragistics digitally signed the assemblies contained in the toolset. This was done to accommodate the Windows Vista Certification Logo requirement that all assemblies in a program contain an Authenticode certificate.Adding this digital signature helps to ensure security, but may affect the performance of your application.Note that Infragistics did not include a digital signature for the assemblies in NetAdvantage for .NET 2007 Volume 1 for CLR 1.x. This product is not supported for use with Windows Vista, and thus should not need to satisfy the Windows Vista Certification Logo requirements.
Did you ever find out any solution to this? I have a similar problem with Infragistics 8.1.20081.1000.
I am not using any special colours / languages / components etc - it just is slow...
Thanks!!!
James
