I'm creating a report using the infragistics.reports.report assembly. With section i'm adding text and tables to the report.At one point i want to draw a line under an ammount. The underline style doesn't meet our requirements because the line has to be longer then the text.
I'm trying to use the addline method in the iSite assembly. For this method to work you need to pass along x and y coordinates. How can i find the x and y coordinates in the report from the current position or from the last text that has been added?
Jacob Iedema
Hi Mike,
I'm creating an invoice generator with infragistics.Reports. My problem is that I need to report a subtotal on the bottom of each page of the invoice. I thought I could do it with something like coordinates, but as you said there are no things like that in the reports, I'm wondering how I can make it possible.
Do you have an exemple that I could inspire ?
Ok thx Mike.
Hi Jacob,
I don't believe there is any way to do this. At least, there is no property or method that will tell you the exact coordinates of the text. You could probably guess by keeping track of the text you wrote the to ISite, but if any of the text wraps, you will not have any way to know it. All of that happens when the document is published, not in the Report object itself.
