Hiya,
I am having (yet) another problem with this control. When applying a style on a large piece of text, the application just hangs on the EditInfo.ApplyStyle command. I haven't been able to narrow down the cause, but is this something you have seen before?Thanks,Campbell
I had been using 10.3.20103.2067, and I upgraded to 10.3.20103.2145.
Hi Campbell,
Thank you for replying with your solution. It is likely that in this case the behavior that you were observing was being caused by a development issue present in the earlier build, (not yet noted on thread); installing the latest service release in these instances is recommended.
If you could, please reply with the version and build that you were using previously; just in case this information is helpful for other users.
If you have any questions that I may assist you with, please let me know.
Sincerely,Chris KDeveloper Support EngineerInfragistics, Inc.www.infragistics.com/support
Actually, ignore me. I downloaded the latest service release and that seems to have resolved it.
