I am using an ultragrid on my app.
If the user double-clicked a row, the row is deleted from the grid. I wanted to show some effects (fade out, for example) before the row dissapear.
It tar possible?
Thanks in advance.
Best regards,
Maria
Hi Maria,
There isn't any built-in functionality for this, but it seems to me that you could implement this yourself by using the Appearance.AlphaLevel for the row, along with a timer.
I put together a quick sample to demonstrate the technique and I have attached it here. Here's what the code looks like:
public partial class Form1 : Form { List<RowAlphaInfo> rowAlpaInfos = new List<RowAlphaInfo>(); public Form1() { InitializeComponent(); } private void ultraGrid1_DoubleClickRow(object sender, Infragistics.Win.UltraWinGrid.DoubleClickRowEventArgs e) { this.rowAlpaInfos.Add(new RowAlphaInfo(e.Row)); this.StartTimer(); } private void StartTimer() { if (false == this.timer1.Enabled) this.timer1.Start(); } private void timer1_Tick(object sender, EventArgs e) { short increment = 15; // Copy the rowAlphaInfos into an array. This will allow us to remove items from the // List without affecting the foreach iterator. RowAlphaInfo[] rowAlphaInfos = this.rowAlpaInfos.ToArray<RowAlphaInfo>(); foreach (RowAlphaInfo rowAlphaInfo in rowAlphaInfos) { UltraGridRow row = rowAlphaInfo.Row; rowAlphaInfo.Alpha -= increment; short alpha = rowAlphaInfo.Alpha; if (alpha > 0) { row.Appearance.AlphaLevel = alpha; row.RowSelectorAppearance.AlphaLevel = alpha; } else { this.rowAlpaInfos.Remove(rowAlphaInfo); row.Delete(false); } } if (this.rowAlpaInfos.Count == 0) this.timer1.Stop(); } } public class RowAlphaInfo { public RowAlphaInfo(UltraGridRow row) { this.Row = row; this.Alpha = 255; } public UltraGridRow Row { get; set; } public short Alpha { get; set; } }
