750
column style set to button and image justification
Hi!
I've looked around a little on this form and haven't seen this problem. Here's the situation: I have a column in a grid with a style Button and a datatype bitmap. First problem is possibly more of a misunderstanding on my part, to properly display the bitmap I have to set the set both the ButtonAppearance.Image and the cell Value to the bitmap. Otherwise I only see the bitmap when I mouse over the button (without clicking on it). I have the CellActivation set to ActivateOnly.
The first problem is tolerable, since it has no effect on the user. The second problem is what's forced me to post. I set both the Value and the ButtonAppearance.Image to the desired bitmap value the the bitmap is displayed nicely. However, when I mouse over the cell/button (again without clicking on the cell) it left justifies the image. When I mouse out of the cell, it returns to center justification.  Take a look at the attached image.
When I click on the button it leaves the image left justified until I move out of that cell. It's as if there's a separate Appearance object for the cell when it's activated. So far I've only found three places that could potentially control the justification:
  • Column appearance: this is set for all values in the column. I've set the HAlign and VAlign to Center and Middle, respectively, inside the designer.
  • Cell.ButtonAppearance: this is a property on the cell itself. Again I've set HAlign and VAlign.
  • Cell.Appearance: again, I've set the HAlign and VAlign values.
Any ideas how I can fix this? Is there an appearance setting for an activated or highlighted (mouse-over) button/cell?
Thanks!
Craig
