Still new to WinGrid. Can someone point me to a code example that will accomplish this task? I'm trying to populate text boxes based on a selected UltraGrid row.
-Todd
HI Mike,
I current have binded textbox to same dataset as the ultragrid.
The problem i am facing is that in a particular scenario, the data does not update.
Scenario 1:
1. Select the row you want to edit
2. Edit the data in textbox.
3. select the already selected row
4. Close the form. (closing of form has the logic to save the changes in the dataset to db)
Though the dataset shows that it has the changes made, but the same does not go to the db.
Any idea?
Hi Todd,
todd45040 said:Finally got it figured out. I changed the event from AfterRowActivate to ClickCell.
The problem with this is that if the user changes the active row without clicking (by using the keyboard), it won't fire.
I don't understand why you are having a problem with AfterRowActivate. The row with an index of -1 may be the FilterRow or the TemplateAddRow. But either way, it shouldn't matter, you can just skip that row.
As for why the event fires when you are adding your data initially, I'd have to see the code where you are adding the data to know what's happening. It sounds to me like you are adding the data into the grid instead of into the DataSource. Or you are using AddNew instead of Add on your DataSource. But since I don't even know what kind of DataSource you are using, it's hard for me to guess.
Finally got it figured out. I changed the event from AfterRowActivate to ClickCell. Then changed how I instanciated the row:
Dim row As UltraGridRow = e.Cell.Row
I also changed my if statement to also check to see if the row count is greater than zero:
If (row IsNot Nothing AndAlso row.Cells.Count > 0) Then
Bottom line, it's working!
Thanks again for you help Mike,
Mike,
It was looking at the first row which had an index of -1. I think that’s the header row or something. I changed the code to avoid row -1.
Private Sub ultragridEmp_AfterRowActivate(sender As Object, e As System.EventArgs) Handles ultragridEmp.AfterRowActivate 'MsgBox("inside ultragridEmp_AfterRowActivate()") Dim row As UltraGridRow = Me.ultragridEmp.ActiveRow If (row IsNot Nothing AndAlso row.Index > -1) Then txbxEmpFirstName.Text = row.Cells("First Name").Text txbxEmpLastName.Text = row.Cells("Last Name").Text Else txbxEmpFirstName.Text = String.Empty txbxEmpLastName.Text = String.Empty End If End Sub
I'm going to do a little further checking, but I think this solved my problem.
Thanks again Mike,Sorry for this dumb question; is the key the column name "First Name" I used when creating the UltraGrid column?These are the lines of code I used to create the grid columns earlier in my code: Dim col1 As DataColumn = New DataColumn("First Name", GetType(System.String)) Dim col2 As DataColumn = New DataColumn("Last Name", GetType(System.String))
Also, when initially loading the grid with rows, how do I prevent the "ultragridEmp_AfterRowActivate" event from firing on each row? I wasn't expecting it to fire until a user clicks on a row in the grid.
Thanks again. I really appreciate you help getting through this.
