2115
Is there a AfterRowChange event?
Currently I'm using the InitializeRow to set the color of the Row. This works fine until the datasource connected with the UltraGrid is changed. When that happens, no InitializeRow is executed. The values in the row change but I don't seem to find a way to detect this. If the values change, then the colors might also be changed.
I've tried AfterRowUpdate but that only gets fired if data goes from the UltraGrid to the Datasource... In my case a Refresh of the data might be done which recycles the existing rows not firing an InitializeRow event.
The colors vary according to a value of a column, so I do need to do it this way.
Thx, Lieven Cardoen
