How can i maintain the scroll postion of ultrawintree control to the selected node .it always gets reset and move BACK TO THE ROOT NODE .. I AM USING C# CODE
Hi. I've only seen that happen when the datasource is reset. Do you have a simple sample that reproduces this behavior when you are not changing the datasource?
There is no code to reset the scroll bar. i have a ultrawintree with some data. I scroll to a record in the middle of the screen and click the cell . then the scroll bar automatically goes to the staring position
What else are you doing? Resetting the DataSource? Do you have a small sample that demonstrates what you mean? What steps do you take that cause the scroll position and selected node to be reset back to the root node?
