Hey guys,
I'm trying to add a bit of glam to our app... in particular...
We have a grid with some rows having a checkbox. Some rows are not to be tickable though. I can hide the cell in InitializeRow with:-
e.Row.Cells["Assigned"].Hidden = true;
However... customers will be all "Heyyy, why cant I tick this row?". So the plan is to put an icon in it, and show what the icon means outside the grid.
My initial thought was to get the actual CheckBox object within the cell and set that to hidden, then set the .Image for the cell... but I can't figure how to get the actual CheckBox, rather than the cell.
Can anybody help?
Awesome, thanks!
I won't mention which approach I took
There are a number of ways to do this. One way would be to use a CreationFilter and replace the CellUIElement with an ImageUIElement.
CreationFilters can be a little daunting if you have never used them before, but they are very powerful and worth the time it takes to learn. If you want to try that approach, I recommend checking out the Infragistics Knowledge Base for sample CreationFilters. Also, get the Infragistics UIElementViewer Utility. It's a big help when dealing with UIElements. If you have any questions about this approach, I will be happy to try to help.
If you want to take the more mundane approach, you can use an editor. Here's what you do:
