Hi there, I'm using ultracomboeditor with dropdownstyle set to 'DropDownList'. Also I have set the autocomplete mode to "Append'.
My drop down has the following values: eg. Value set to intger eg. "1", display text set to eg. "1. test1"
Following are sample display text values:
1. test1
2. test 2
3. test 3
4. test 4
11. test 11
26. test 26
30. test 30
31. test 31
32. test 32
33. test 33
34. test 34
When the form loads, I key in "2" in the dropdown and it goes to the "26. test26" value which is correct. Then i key in "3" in the dropdown, which then it will go straight to "30. test 30" but NOT to "3. test 3". I want when I'm in 26, and when i press '3', it should go to "3. test 3".
Is it the normail behaviour?? Why cant we go to the top of the list to search?
my code: this.uComboBillingGroup.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
this.uComboBillingGroup.DropDownStyle = Infragistics.Win.DropDownStyle.DropDownList;
this.uComboBillingGroup.DataSource = dt; this.uComboBillingGroup.ValueMember = "group_id";
this.uComboBillingGroup.Value = bill_id;
this.uComboBillingGroup.DisplayMember = "description";
Could u please be able to help me with a solution ASAP??
Thanks in Advance!! NW
Hi Boris,
Sorry the above is not working at the moment when I did more testing on it! :'((
I found this new feature in the version 10.3 called AutosuggestFilterMode and when we set that to "StartWith" it automatically does the above!!! (Keeping the AutoCompleteMode = Append and DropdownStyle = Dropdownlist)
Unfortunately we are using the older version for this project ( 9.2) and we are not in a stage to change it the newer version.
Is there any way i can implement that feature programmatically?? If there is it would be great!!!
Thanks in advance!! looking forward to hear from you ASAP! Appreciate it!!
NW
Thanks alot for your reply.
Actually I did a small change and then it worked!!
if (!ultraComboEditor1.Text.ToString().StartsWith(e.KeyChar.ToString())) { if(ultraComboEditor1.ValueList.FindByDataValue(e.KeyChar.ToString()) != null) ultraComboEditor1.Text = ultraComboEditor1.ValueList.FindByDataValue(e.KeyChar.ToString()).DisplayText; }
Thanks again!
Could you please try the following code and let me know if it works for you:
private void ultraComboEditor1_KeyPress(object sender, KeyPressEventArgs e)
ultraComboEditor1.SelectedItem = ultraComboEditor1.ValueList.FindByDataValue(e.KeyChar.ToString());
