Hi there,
I've got an UltraComboEditor in which I am displaying a custom image for each item.Each image is 24x24 pixels.I can make it display nicely for the selected item by setting AutoSize = false; and then increasing the control height accordingly.However, when view the items in the drop down list, the images are shrunk down and look poor.If I increase the font size, the image looks good, but the text is way too big!
Is there any way that I can override the height of each list item such that the image displays nicely, rather than being based on the font size?
Cheers,
James
Hello James,
When I tried Mike's suggestion myself, the dropdown height increased to show the default 8 items. Which version of NetAdvantage are you using? It's possible the issue you described was resolved in a later version.
I've cracked it...
I actually had the first item in the list without an image.I'm guessing that drop down height is calculated as MaxDropDownItems (8) * First Item Height
Setting an image on the first item fixed everything!
Many thanks,
Following up... increasing MaxDropDownItems to 18 instead of 8 let's me see the 8 I want!!
I don't mind going down this route, but would prefer a more intuitive approach! :O)
Hi Mike,
Thanks for the swift reply!!
That's resolved it, but created another issue...
With ScaleImage.Never, the drop down list height it still being calculated based on the font size.This means that I now only see 3 items in the list instead of 8!
Is there an associated property I need to play with to get this looking better too?
Hi James,
This should do it:
this.ultraComboEditor1.ValueList.ScaleItemImage = ScaleImage.Never;
