Hi Leo,
I tested the sample provided above and it appears that the underlying data is being updated correctly. Please provide a sample application that reproduces this issue and I will continue to investigate. If you would prefer not to upload your sample to the public forum, please let me know and I will open a private support case for you.
Hello. I'm having this issue with version 17.1.20171.1008. When the combo is bound to an object, if I clear the combo (removing all characters) the underlying value does not get updated and I cannot even move out of the combo control (the cursor stays in the control and I cannot click nor tab anywhere else). I'm using an UltraCombo (not UltraComboEditor)
Hi. The problem has been solved. I upgraded to Infragistics 12.2 with the latest service release.
Thanks for the support
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
I tried your sample with service release 2135 which is the latest for v11.2 and it worked fine for me in both Win7x64 and Win8x64. I can see that it does not work in 11.2.2050, so we have fixed this.
Could you please download this release(2135) and test your application against it. You could do so from https://ko.infragistics.com/my-account/keys-and-downloads/, then please click on 11.2 version and then on the 'Service Releases' tab.
Let me know if you face any issues.
