I have an UltraGrid displaying data from UltraDataSource.
The weird thing about using UltraDataSource is if certain columns contain key with numbers/special characters, those columns are displays before other columns although no column sorting is done.
For example, the below Grid show Account 12 column before Portfolio column, whereas the underlying UltraDataSource has Account 12 column After Portfolio column.
Is there any reason for this? How can I prevent the Grid from automatically sorting the columns so.
Sangeetha
Thanks Danko, I attached this way in another post and it worked.
Thanks Michael.
This is not a workaround but simply what you have to do if you want to control the order in which the columns appear in the grid. Let us know if you have further questions.
Hello Sangeetha Thai,
Thanks for your feedback.
If you would like to attach images directly to the post, you could use the "OPTIONS" tab, when you are replying to a post and there is "File Attachment" option that will allow you to post your screenshot.
Please feel free to let me know if I could assist you further with this matter.
No luck - the Image just won't show up. But thanks anyway Mike.
