I need to have 2 rows of summary fixed at the bottom of my grid. Is this possible? If not possible, then is it possible to have multiline (word wrap) in the summary cells? I tried but I couldn't get the summary row to adjust its height automatically.
Thanks!
Thank you for posting on our forum.
As of now there is no built-in functionality to display a specific summary in multiple lines when its value doesn't fit the column width. Like mentioned above the summary lines are determined automatically based on number of summaries set on that column.
I think Michael mean multiline for one summary (when a value does not fit in the column width)
It is possible somehow to make, that value which does not fit was moved on the second line?
Hi Michael,
I think the number of summary lines is determined automatically. If you add two summaries to the same column, you should get two lines. Or if you have fixed summaries (summaries aligned to a column) and freeform summaries (summaries aligned left, right, or middle), they always show up on two different lines.
