I'm using vs. Infragistic Net 2010 with v8 (2008) and when developing a project in C # controls disabled Infragistic leave me alone UltraChart control enabled.Someone can help me find out what the problem?
thanks
thanks, the problem was the version of the framwork, the change to the 3.5.
greetings.
Hello Carlos,
Did you try compiling your project against .NET 3.5 or any other version?
If this does not help - are you using a wireless mouse or keyboard? If you are, please try again after installing the latest drivers for the devices. If this does not help too, try with a wired keyboard and mouse and let me know of the result. Basically, since you have the chart enable, I believe that it is the first case, with the .NET version here.
