470
ISL Overriding Backcolour
I've got an ISL (slightly modded version of one of the samples, can't remember which) which changes amongst other things the highlighed/active row colour to grey.  The problem is I'm setting the backcolour of some of the cells on initializerow but when using the ISL selectedappearance and activeappearance are ignored.  No ISL and the colours work fine.
I'm sure it's a simple mod to the ISL or code but I'm struggling to find it.. can you help?
If e.Row.Cells("MyValue").Value = True Then
                e.Row.Cells("MyField").Appearance.BackColor = Color.LimeGreen
                e.Row.Cells("MyField").SelectedAppearance.BackColor = Color.LimeGreen
                e.Row.Cells("MyField").ActiveAppearance.BackColor = Color.LimeGreen
End If
  • 469350
    Setting an Appearance on a cell should override the Isl file settings. If that's not working then something is wrong.
    Can you post a small sample project demonstrating the issue so we can check it out?
