The UltraMessageBoxManager forms can be closed using Alt+F4. When this occurs, they do not return with one of the expected DialogResult values. The x in the upper right-hand corner is disabled (which should normally indicate that they have to select one of the available options to continue and cannot close the form with Alt+F4).
The standard Windows MessageBox form cannot be closed with Alt+F4. You always have to click a button (or press enter/escape). As a result, they always return one of the expected DialogResult values. Is there a way to disallow the user from closing an UltraMessageBoxManager form with Alt+F4? Is this a bug or how it is supposed to work?
I have submitted this issue to our development team with reference number 136366. A support case has also been opened for you with reference number CAS-112178-G6C9Z1. You will receive updates on this issue from the support case.
Paul,
I am going to submit this to out development team for further review and I will get back to you with a reference number as soon as I have done so.
Thanks.
Okay, I see the problem now. I think the key is that the buttons have to exclude the Cancel button. This is clearly a bug, so I forwarded this thread over to Infragistics Developer Support so they can create a case for you and write this up for developer review.
Here is the code:
if (DialogResult.Yes != UltraMessageBoxManager.Show("Are you sure you would like to remove this appointment?", "Remove Appointment", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)) return;
A screenshot of the message box is attached. Notice that the close button in the right-hand corner is disabled. Alt+F4 causes the message box to be closed with a DialogResult value of Cancel (which is not Yes or No). The standard Windows MessageBox does not allow the message box to be closed with the same exact parameters.
Windows version:
if (DialogResult.Yes != MessageBox.Show("Are you sure you would like to remove this appointment?", "Remove Appointment", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)) return;
