I have a grid that can be sorted on any column except for one. It doesn't make sense to sort on it because it just contains images. Is there a way to keep the user from sorting on that column (and therefore not changing the previously sorted column)? Can I intercept the header click?
I'm using NetAdvantage 10.2
thanks
Mario
Hi Mike,
Thanks! I didn't notice the Disabled value on the SortIndicator enum.
Hi Mario,
It doesn't matter whether the sorting is external or not. What you do is set the SortIndicator on the column to Disabled.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { UltraGridLayout layout = e.Layout; UltraGridBand band = layout.Bands[0]; UltraGridOverride ov = layout.Override; ov.HeaderClickAction = HeaderClickAction.ExternalSortMulti; band.Columns["Image 1"].SortIndicator = SortIndicator.Disabled; }
I forgot to mention that I'm sorting externally.
