855
Removing columns takes a long time
I have the following code to remove a column:
            ultraDataSource1.Band.Columns.Remove(colKey);
            UltraDataBand band = ultraDataSource1.Band;
            while (band.ChildBands.Count > 0)
                band = band.ChildBands[0];
                band.Columns.Remove(colKey);
Removing the column from the final band takes a long time.  My data is setup as follows:
The initial band contains about 30 rows of data, and each of those contains about 30 rows in their child band.  Then each of those child rows has one or two rows in the band below it.
Is there a way to speed up removal of a column?
Thanks.
-Nick
