hello
Depends on another column cell value sometimes in this column must populate valuelist but samoetimes not, only editable cells.Not valuelist.Only in one column.is it possible?For example on another column if selected city this column will populate valuelist,if select street this column will not populate valuelist.only editable cell,to edit yourself.
I believe that this topic has already been discussed in the following forum thread, so let us keep the conversation there: http://ko.infragistics.com/community/forums/p/78434/396689.aspx#396689.
Thank you.
