1380
Grids checkbox column
There are grid with two column.First checkbox column,secon dropdownlist.
 I need to get  second column value which checkbox is checked.
Thanks in advance.
  • 2145
    Verified Answer
    Should be a simple case of looping down the grid until the value of the check box is true.
    i.e.
    For each urow in mygrid.rows
    if urow.getcellValue("CheckboxColumn") = true then
    msgbox(urow.getcellvalue("MyListboxColumn))
    end if
    next
    Looping in the grids in infragistics I have found to be really quick, even with alot of data.
