Hi, I try this code but get error - cannot find key name.I checked key names, they are same.Any idea?
private void ultraGrid_CellChange(object sender, CellEventArgs e) { if (e.Cell != null) { if (e.Cell.Column.Key == firstColumnName) { ValueList vl = ultraGrid.DisplayLayout.ValueLists["secondColumnName"]; var item = vl.ValueListItems[0]; } } }
Ilkin said:I checked key names,
What key names are you checking and how are you checking them? If you are getting an error that says "Key not found", then there is no ValueList in the ValueLists collection with the key you have here.
