2115
Is there a way to position Tooltips for the UltraStatusPanel above the Panels instead of below?
Now they appear kind off under the mouse pointer, probably because my UltraStatusBar is the most bottom Panel... If I compare it with Outlook for instance, in Outlook the Tooltips appear above the mouse pointer.
  • 469350
    I need a little clarification.
    First... which control are you using? There is no UltraStatusPanel control that I know of. I'm guessing you meant UltraStatusBar. Is that right?
    I tried it out with UltraStatusBar and I was able to reproduce what you described, but only if the form is maximized on a secondary monitor where there is no Windows task bar. This looks like a bug to me. The tooltip should not obscuring the panel or be obscured by the mouse.
