20
UltraToolBar double-click issue
I have a problem with UltraToolBar double-click. When users double-click a tool on the toolbar of a form to open another form, the system treats it as two single clicks. The first click opens another form (as a MDI child) which in turn has its own toolbar, the second click fires toolclick event for a tool on the toolbar of the second form and open an unexpected form. I tried to use ToolDoubleClick event handler to do something but this event handler has never got fired since Infragistics treat double-click as two separate single clicks.
Please give me some advices.
Huan Truong
  • 44743
    Apparently the ToolDoubleClick event was originally intended for only the LabelTool and editor tools. You can submit a feature request for this event to fire with other tools here: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
    You can also workaround this in the ToolClick event with the following code:
    private Point lastClickedLocation = new Point( -10000, -10000 );
    private Stopwatch timeSinceLastClick = new Stopwatch();
    private string lastClickedToolKey;
    private void ultraToolbarsManager1_ToolClick( object sender, ToolClickEventArgs e )
     Point currentPosition = Cursor.Position;
     bool isDoubleClick = false;
     if ( this.timeSinceLastClick.IsRunning &&
      this.timeSinceLastClick.ElapsedMilliseconds <= SystemInformation.DoubleClickTime &&
      this.lastClickedToolKey == e.Tool.Key )
      Size maxSize = SystemInformation.DoubleClickSize;
      if ( Math.Abs( this.lastClickedLocation.X - currentPosition.X ) < Math.Abs( maxSize.Width ) &&
       Math.Abs( this.lastClickedLocation.Y - currentPosition.Y ) < Math.Abs( maxSize.Height ) )
       isDoubleClick = true;
     if ( isDoubleClick )
      this.ToolDoubleClick( e.Tool );
      this.lastClickedToolKey = null;
      this.timeSinceLastClick.Stop();
      return;
     this.lastClickedLocation = currentPosition;
     this.lastClickedToolKey = e.Tool.Key;
     this.timeSinceLastClick.Reset();
     this.timeSinceLastClick.Start();
     //switch ( e.Tool.Key )
     //    // Do normal tool click processing code here
    private void ToolDoubleClick( ToolBase tool )
     //    // Do tool double click processing code here
