Hi. I'm hoping there's a simple solution to this problem:
I'm using the 10.2 set of controls. I have a grid connected to a UltraDataSource control. When I delete a row from the grid, the data source RowEndEdit event fires. I normally use that event to do some formatting of edited data depending on what it it. However, when I delete a row, I don't want to do any formatting - I just want to exit the method.
My question: Is there some way to tell that I'm in the RowEndEdit event when a row is being deleted? I can try to track this with flags but that's not an ideal solution.
Please let me know if there's some way to know when a row has been deleted so I can skip the usual row processing.
Thanks.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
Thank you for using Infragistics Components
