1365
Show data value of single point
Dear experts,
I've followed the following example from this forum (because i'm learning to use the UltraChart):
this.ultraChart1.ChartType = Infragistics.UltraChart.Shared.Styles.ChartType.ScatterChart;
XYSeries series1 = new XYSeries();
series1.Points.Add(new XYDataPoint(1, 0.1, "", false));
series1.Points.Add(new XYDataPoint(2, 0.2, "", false));
XYSeries series2 = new XYSeries();
series2.Points.Add(new XYDataPoint(3, 0.2, "", false));
series2.Points.Add(new XYDataPoint(4, 0.3, "", false));
this.ultraChart1.Series.Add(series1);
this.ultraChart1.Series.Add(series2);
Works fine. In the wizard you can check that you want to "Show data value on chart". This will show ALL data values per point in the chart. But for a real world problem of mine I would like to show the 'data value'  of a single point of 1 serie on the chart.
So for example in the above code, if I would like to show the data value of the 2nd point in series 1. How would I do that?
Thank you very much in advance for answering.
