3045
Column width differs between loading and shown state?
I'm trying to track the original column widths during the load event of the form. I noticed that the width are actually slightly wider once shown. When I display the value of the column widths inside a button click event, they are different from what was reported during the load event.
Any idea? I'm using AppStylist.
  • 469350
    It's tough to guess since there are so many variables here. If you have not explicitly set the Width of each column, then the width is auto-calculated by the grid. So that could be happening here.
    It could also be that you are loading a Layout or a Preset into the grid and this is changing the column widths.
    Or, you could be calling the PerformAutoResize method or setting the AutoFitColumns property.
