I have a simple example chart to show the issue. In a 2-series column chart, without using SecondaryY axis, the chart shows with the columns for each x axis data point next to each other, how we want it. (see screenshot) I have purposely set the values in the 2nd series to a different "range" than the 1st.
When adding the AxisY property to the 2nd series, the sencond Y axis shows properly, but the columns for each series are lined up on top of each other. (see screenshot)
Am I using the Axis settings incorrectly, or is this the expected behaivor? If so, is there any way to get the columns next to each other when using 2 Y axes?
Dim dt As New DataTable() dt.Columns.Add("Items", GetType(String)) dt.Columns.Add("Miles Column", GetType(Decimal)) dt.Columns.Add("Fillups Column", GetType(Decimal))
dt.Rows.Add("Item 1", 110, 20) dt.Rows.Add("Item 2", 115, 30) dt.Rows.Add("Item 3", 120, 40) dt.Rows.Add("Item 4", 125, 55)
ultraChart1.ChartType = ChartType.Composite ultraChart1.BackColor = Color.Black ultraChart1.Data.ZeroAligned = True ultraChart1.TitleTop.Text = "Miles to Fillups Analysis" ultraChart1.TitleTop.FontColor = Color.Yellow ultraChart1.TitleTop.Font = New Font("Arial", 14.0F) ultraChart1.TitleTop.HorizontalAlign = StringAlignment.Center
' Create the Chart Area Dim area As New ChartArea() area.BoundsMeasureType = MeasureType.Percentage area.Bounds = New Rectangle(25, 10, 74, 90) area.Border.Thickness = 0
Dim xAxis As New AxisItem()
xAxis.OrientationType = AxisNumber.X_Axis xAxis.DataType = AxisDataType.String xAxis.SetLabelAxisType = SetLabelAxisType.GroupBySeries xAxis.LineColor = Color.White xAxis.Labels.SeriesLabels.Visible = False xAxis.Labels.Visible = False xAxis.MajorGridLines.Visible = False
Dim yAxis As New AxisItem() yAxis.OrientationType = AxisNumber.Y_Axis yAxis.Extent = 60 yAxis.TickmarkStyle = AxisTickStyle.Smart yAxis.DataType = AxisDataType.Numeric yAxis.LineColor = Color.White yAxis.Labels.FontColor = Color.White yAxis.Labels.ItemFormatString = "<DATA_VALUE:#0>" yAxis.Labels.HorizontalAlign = StringAlignment.Far yAxis.RangeType = AxisRangeType.Custom yAxis.RangeMin = 100 yAxis.RangeMax = 200
Dim y2Axis As New AxisItem() y2Axis.OrientationType = AxisNumber.Y2_Axis y2Axis.Extent = 50 y2Axis.TickmarkStyle = AxisTickStyle.Smart y2Axis.MajorGridLines.Visible = False y2Axis.DataType = AxisDataType.Numeric y2Axis.LineColor = Color.White y2Axis.Labels.FontColor = Color.White y2Axis.Labels.ItemFormatString = "<DATA_VALUE:#0>" y2Axis.RangeType = AxisRangeType.Custom y2Axis.RangeMin = 0 y2Axis.RangeMax = 60
Dim columnSeries As New NumericSeries() columnSeries.DataBind(dt, "Miles Column", "Items") columnSeries.PEs.Add(New PaintElement(Color.Gold)) columnSeries.Label = "Miles Column"
Dim columnSeries2 As New NumericSeries() columnSeries2.DataBind(dt, "Fillups Column", "Items") columnSeries2.PEs.Add(New PaintElement(Color.Red)) columnSeries2.Label = "Fillups Column"
Dim ColumnLayer As New ChartLayerAppearance() ColumnLayer.ChartType = ChartType.ColumnChart ColumnLayer.Series.Add(columnSeries) ColumnLayer.ChartArea = area ColumnLayer.AxisX = xAxis ColumnLayer.AxisY = yAxis ColumnLayer.AxisY2 = y2Axis ColumnLayer.SwapRowsAndColumns = True
Dim ColumnLayer2 As New ChartLayerAppearance() ColumnLayer2.ChartType = ChartType.ColumnChart ColumnLayer2.Series.Add(columnSeries2) ColumnLayer2.ChartArea = area ColumnLayer2.AxisX = xAxis ColumnLayer2.AxisY = y2Axis ColumnLayer2.SwapRowsAndColumns = True
area.Axes.Add(xAxis) area.Axes.Add(yAxis) area.Axes.Add(y2Axis) ultraChart1.CompositeChart.ChartAreas.Add(area) ultraChart1.CompositeChart.ChartLayers.Add(ColumnLayer) ultraChart1.CompositeChart.ChartLayers.Add(ColumnLayer2) ultraChart1.CompositeChart.Series.Add(columnSeries) ultraChart1.CompositeChart.Series.Add(columnSeries2)
Have you been able to resolve your issue ? If you still have any concerns or questions I will be glad to help. If you need any additional assistance don’t hesitate to ask.
Regards
This is the sample
Hello David,
If I understand well your requirements, maybe one possible approach to solve this task could be if you are using FillSceneGraph event. Please take a look at the attached sample for more details and let me know if you have any questios.
I have got this issue too in Windows Form NetAdvantage 2011.1.
