In the ultrawingrid is it possible to have 2 seperate cells under 1 column heading?
The 2 cells are related so I want the user to know this and enter both values in.
There are a couple of ways you can do this.
Using Groups, you can group related columns together. You do this by adding Groups to the Band, then assigning each column to a group. If you have groups, then every column must be in a group in order to be visible.
The other way to do it would be to use RowLayouts.You would set the LabelPosition on the two columns in question to None. Then create a dummy unbound column whose LabelPosition is LabelOnly and arrange it so it spans the two columns.
I have tried the group column approach. although it does work it doesn't have the flexibility of moving the columns between groups.
I tried setting the rowlayouts labelposition property on the 3 columns but nothing seems to happen. The new dummy column was set to labelonly but when I resize it the column beside it shifts over as it would normally instead of overlapping the column label beside it.
the other columns have had the labelposition property set to none.
Any ideas?
When I set the LabelPosition property of the dummy column to LabelOnly the cell is removed leaving only the column header.
The problem is that I cannot resize the column, it remains at a constant size.
When I resize it the properties box shows the changes to the width, spanx etc
But in the editor the column header still remains the same size.
Ok I've managed to get it working somewhat.
Is it possible to move columns programmatically as when I move the dummy column to a different location in the wingrid it leaves behind the 2 columns under it.
Yes, it is possible to move columns programmatically. You would do this by changing the LayoutInfo properties on the column. It's a little more complicated than you may be used to, though. You really need to understand GridBagLayouts and how they work. You probably want to change the OriginX and OriginY in this case.
Hi
I am able to group the columns under a group but i dont want individual column headers to appear. Its enough if the group Header appears , is there any way to remove those column headers under a group or set visible = 0. Would be great if you can provide some help on this
Thanks & Regards
Keerti Somasundaram
Hi Keerti,
If you are using RowLayouts, then you can hide a column header using the LabelPosition property. You would have to set this on the LayoutInfo of each column.
If you are not using RowLayouts, then you can just use the ColHeaderVisible property on the Override object.
