I developing an application having 3 dockareas with group treecontrol an a tabgroup of dynamically added tab
see attached document:
1. save/load layout without restarting the app in between doesn't work
2. save/load layout an adding further tabs to the tabgroup doesn't work
any idea why the save/load lead to an wrong irreversible layout state ?
Hi kagel,
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
I went through the doc file you have attached. I do not understand what is wrong exactly, the two tabs are added normally, I might be missing something of course. Can you point out exactly what is the issue with these two tabs? Also, please note that I cannot know for sure how this is working in your project since I do not have a sample in front of me, can you make such sample?
