When I use the DataGridView Windows Forms control, there is a CellValidating event. This gets called when the cell loses focus. In addition, when I click the Save ToolStripButton on my form, since this doesn't cause a transfer of focus, I call the Form.ValidateChildren() method. This also causes the CellValidating event to fire. If the data is invalid, I can abort the save operation. Something like this:
Private Sub SaveToolStripButton_Click(ByVal sender As Object, ByVal e As EventArgs)
If Me.ValidateChildren()
SaveDataToDatabase()
End If
End Sub
Private Sub DataGridView_CellValidating(ByVal sender As Object, ByVal e As CellValidatingEventArgs)
If (cell value is not valid)
e.Cancel = true
However, I cannot find an equivalent event for the UltraWinGrid. I've tried making use of the BeforeCellUpdate and BeforeRowUpdate events, as well as the BeforeExitEditMode event. There seems to be no easy way to do this if the focus of the cell is not being lost.
Given that I am using the UltraWinGrid, and given that the save operation is initiated by clicking on a ToolStripButton, what is the best way to validate data in an UltraWinGrid and prevent the save operation from taking place? Obviously, I would also like to deliver feedback to the user that there is a validation problem.
What you are looking for is the grid's UpdateData method. This forces the grid to commit any pending changes, as though the grid lost focus.
You may also want to use the grid's PerformAction method can perform the ExitEditMode action before you call UpdateData to make sure that the cell can exit edit mode safely.
