Is it possible to control cell padding on UltraGrid using appstylist? I am using v12.2 controls.
Thank you
Hi witepo,
I created the following case for you: 'CAS-115785-Q8C3C6' and will update you through it.
The properties you are able to change are exposed in the "Properties - Default - UltraGrid" and the "UltraGrid-specific Properties" panels. These two would show at the bottom-left of the 'AppStylist' after marking the 'UltraGrid' button from the 'Roles' panel.
The mentioned property is not there, this could be changed at design time and run-time.
Please do not hesitate to contact me if you need any additional assistance.
