I am trying to save the MDI state when closing the application and load it when opening. Like FireFox, it opens all the web pages last time when you close the application. I've noticed that UltraTabbedMdiManager have methods like SaveAsXml and LoadFromXml.What is contained in the saved XML file?
What do I need to do if I want to open the last visited pages like FireFox? Thanks.Mike
It looks like OptionField in Serializable class does not work when using SOAP formatter.http://connect.microsoft.com/VisualStudio/feedback/ViewFeedback.aspx?FeedbackID=140592
I implemented ISerializable interface for the class, and added my own serialization and deserialization method to handle optional fields.It works fine now. Thanks.
I am not sure what the problem is from the stack trace. It could be a problem with the application or the tabbed mdi manager. I would recommend submitting a sample and the old layout file to the support group so it can be investigated further: http://ko.infragistics.com/gethelp.
Mike Dour"]In the handler, you can get the PersistedInfo for the tab and create a Form (or use an existing Form) to use for the tab. Set the Form on the Form property of the event arguments.
I successfully save the xml and load when opening.
Now I need to add more information to the PersistedInfo object, e.g., some state information of the child form. I have a Serializable class called MdiChildFormState to save to PersistedInfo, and I added the new members with [OptionalField()] attribute.
Then I tried to load the old version of the MDI layout file (without new memebers), and I got the following exception: [System.ArgumentNullException] {"Member at position 1 was null.\r\nParameter name: members"} System.ArgumentNullException
and ex.StackTraceis like the follows: at System.Runtime.Serialization.FormatterServices.PopulateObjectMembers(Object obj, MemberInfo[ members, Object[ data) at System.Runtime.Serialization.Formatters.Soap.ReadObjectInfo.PopulateObjectMembers() at System.Runtime.Serialization.Formatters.Soap.ObjectReader.ParseObjectEnd(ParseRecord pr) at System.Runtime.Serialization.Formatters.Soap.ObjectReader.Parse(ParseRecord pr) at System.Runtime.Serialization.Formatters.Soap.SoapHandler.EndElement(String prefix, String name, String urn) at System.Runtime.Serialization.Formatters.Soap.SoapParser.ParseXml() at System.Runtime.Serialization.Formatters.Soap.SoapParser.Run() at System.Runtime.Serialization.Formatters.Soap.ObjectReader.Deserialize(HeaderHandler handler, ISerParser serParser) at System.Runtime.Serialization.Formatters.Soap.SoapFormatter.Deserialize(Stream serializationStream, HeaderHandler handler) at System.Runtime.Serialization.Formatters.Soap.SoapFormatter.Deserialize(Stream serializationStream) at Infragistics.Win.UltraWinTabbedMdi.UltraTabbedMdiManager.Load(Stream stream, Boolean xml) at Infragistics.Win.UltraWinTabbedMdi.UltraTabbedMdiManager.LoadFromXml(Stream stream)
Any idea how I can solve this issue?Thanks.
Mike2008
vrn said:I am guessing because ReadBase64 is reading the next node and decoding it, the order of loading the controls is important? So it should be read in the same sequence that I saved it?
Yes, that is correct.
vrn said:Do you have suggestion on how I can make the loading sequence independent of the saving sequence? This can prove useful for my design where I am trying to make each component completely independent of the other. So each component should be able to figure out its own setting from the larger XML file.
Instead of using an XmlTextReader, you can try to implement something using an XmlDocument. Then each control can iterate the child nodes of the document and find the node with their stream name and just read in that node. Alternatively, you could keep the same approach and read in all streams and populate them into a Dictionary<string,Stream>, where the key is the stream name. Then when each control goes to load, they just access the dictionary with the name they are looking for.
Mike Dour"] My code snippet used an XmlTextReader, which just reads the nodes in order, so it did not need to specify the config file it was looking for. I could have put asserts before loading each stream to make sure the current node had the expected names before loading them.
Mike your code worked like a charm!
- I am guessing because ReadBase64 is reading the next node and decoding it, the order of loading the controls is important? So it should be read in the same sequence that I saved it?
- Do you have suggestion on how I can make the loading sequence independent of the saving sequence? This can prove useful for my design where I am trying to make each component completely independent of the other. So each component should be able to figure out its own setting from the larger XML file.
