I have a UltraTabControl with around 5 or 6 tabs.
I am aware there is already a dropdown button that lets the user select from all the visible tabs.
I have been asked to add a new feature for one of our tabs (lets call it Tab3 since it is the third tab in the control).
Tab3's TabPageControl contains information that can be displayed in more than one view.
So far I have created separate tabs for each view. What I'd like to do is combine all views under Tab3 and put a dropdown next to Tab3 to switch between the views.
My current thought is to put a DropDownButton next to Tab3 with all the available views, and still keep each view in a separate tab.
All but the selected view will be hidde.
What's the best way to do this? Or is there a better more efficient way than what I am proposing?
Jason
Hello Jason,
Thank attached sample provides the behavior you are looking for as I understand it. Please run the sample and let me know if you have any questions.
Thanks for the update Michael.
-Jason
Jason,
I want you to know that we are still working on this and we will get back to you with an update later this week.
I have been able to use the creation filter as previously explain to get the desired result; however, I am currently working on finding a way to get the DropDown to popup in the desired location. I will continue working on this next week and provide you with an update.
The behavior you've encountered is occurring because the UltraDropDownButton is on top of the UltraTab. You should be able to prevent this behavior by using a Creation Filter to add the UltraDropDownButton as a child to tab2. To learn more about Creation Filters, please visit the following page in our online help documentation:http://help.infragistics.com/NetAdvantage/WinForms/2013.1/CLR4.0/?page=Win_Creation_Filter.html
I am currently working on implementing this creation filter and will provide you with an update on this post once I am complete.
