Hi, I want an UI as show below. Is it possible with UltraDockManager? Or what can be the best possible way to do it using "Windows Forms"? I want a group of tabs on the top and a group of tabs at the bottom of the strip. When clicked the pane should be visible. I tried using UltraDockManager, but i face a problem to place the tabs on the top. When the pane is pinned, the tabs are moving to the left bottom of the strip. I docked the dockareapane and childpanestyle to left. Now i want the tabs to be on the left top of the strip even after the panes are pinned.
Hello cadcame,
Please take a look at the answers of your questions:
cadcame said:I need the pdf navigation as control to put it in my present main application
cadcame said:But as the printpreview dialog is not a control I couldn't use that
Let me know if you have any further questions.
Regards
Hi Georgie,
Can You reply for the above post. Need some help.
Thank you for reply and the sample application. But as the printpreview dialog is not a control I couldn't use that.I need the pdf navigation as control to put it in my present main application. As our application is itself a form. I cannot have any other dialogue. So just view the image which i have attached. See the steps what i have mentioned. I have been trying this in my own ways. But it would be good if I have a word from experts, so that in the future the design may be simple and can be reusable.
Thanks.
If you need any additional assistance don’t hesitate to ask.
this is the sample
