265
Cannot update unbound column after Sort
I have records stored in a DataTable that is bound to an UltraWinGrid.UltraGrid.  I also have SortMulti enabled and I am able to successfully sort on any combination of columns.
Since the sorting causes the Record ID column to be completely unsorted most of the times (as a result of sorting on other columns), I decided to insert an UNBOUND column called "RowID".
This way, after each time a sorting occurs, I re-write to the RowID column using the grid's AfterSortChange() event.  Example:  RowID = 1, 2, 3, 4, etc.  The problem is that when I do this, my RowID values appear to NOT be updated.  However, after much experimentation, I have come to the conclusion that my attempt to iterate through the Rows collection is a waste of time.  This is because I believe that the ordinal positions of the rows have also been re-arranged due to the sort.
Does anyone have a suggestion on how I can get this working?  I've tried numerous ideas and they all fail -- because of the re-arranged row indexes caused by the sorting.  At least,...this is my belief.
