I can only get so far, the datasource appears to bind but the UltraComboEditor is not displaying any content.
Thanks but I solved the problem. Within my DataSource InitSchema I was setting the Band.Key but not using that value in the ultraComboEditor1.DataMember.
Can you post your code or a sample reproducing the issue? Meanwhile, you could take a look at my sample which is attached to this post and see if it helps.
