When using version 11.2 of the UltraDayView control (CLR 4.0), a horizontal scrollbar would properly appear when there are more Owners than would fit in the control.
However, after upgrading to 13.1, without any other changes in code, the horizontal scrollbar no longer appears when it's needed. The vertical scrollbar continues to properly appear.
Is there a fix or a workaround I could use in order to get the scrollbar back?
Hi Boris,
We are having the same horizontal scroll issue with our product.
It is uses 13.2 version and it is deployed on the customer site.
Since it is deployed to customer it will be difficult for us to change versions of infragistics.
We can upgrade our current projects for a next releases with the new versions of infragistics
But not on customer site. And our customers will not upgrade our software in the near future. They need to fix a current version. Can you give us a patch so we can just run it for our customers to fix the problem?
Thanks Eugenia.
I'm using Infragistics4.Win.UltraWinSchedule.v13.2, and I'm still experiencing the same issue. Did this fix get into the 13.2 release? If not, do you know of a work-around?
Cheers,
Amy
Todd,
This was logged as development issue "143026: Horizontal scrollbar is not displayed even though some of these columns are not in box.". It is now fixed and will be in the next service release for v13.1 of NetAdvantage.
Please do not hesitate to contact me if you need any additional assistance.
Hello Todd,
I created the following case for you: 'CAS-118058-Y1C7F3' and will update you through it. You could see it in your account in the 'Support Activity' page.
