This article demonstrates how to allow cells to be dragged to different locations in an UltraGrid. It is based on the knowledge base article KB010086 for dragging and dropping rows in a WinGrid and it is written in C#.
Step-By-Step Example
1) The first step is to set the UltraGrid’s AllowDrop property to True., the SelectCellType property to SingleAutoDrag and the CellClickAction to CellSelect:
ultraGrid1.AllowDrop = true;
e.Layout.Override.SelectTypeCell = SelectType.SingleAutoDrag;
e.Layout.Override.CellClickAction = CellClickAction.CellSelect;
2) Next, handle the UltraGrid’s SelectionDrag event and call the UltraGrid’s DoDragDrop() method. The SelectionDrag event fires when the end-user clicks and starts to drag a selected cell.
private void ultraGrid1_SelectionDrag(object sender, CancelEventArgs e) { ultraGrid1.DoDragDrop(ultraGrid1.Selected.Cells, DragDropEffects.Copy); }
3) Now handle the UltraGrid’s DragOver event to set the drag effects
private void ultraGrid1_DragOver(object sender, DragEventArgs e) { e.Effect = DragDropEffects.Copy; }
4) Finally, handle the UltraGrid’s DragDrop event and get the position on the grid where the cell is to be dropped. Once we have that location, we can move the cell to it.
private void ultraGrid1_DragDrop(object sender, DragEventArgs e) { int dropIndexRow, dropIndexCol; // Get the position on the grid where the dragged CELL is to be dropped. //get the grid coordinates of the row and columns(the drop zone) UIElement uieOver = ultraGrid1.DisplayLayout.UIElement.ElementFromPoint(ultraGrid1.PointToClient(new Point(e.X, e.Y))); //get the cell that is the drop zone/or where the dragged cell is to be dropped UltraGridRow ugrOver = uieOver.GetContext(typeof(UltraGridRow), true) as UltraGridRow; UltraGridColumn ugrOverCol = uieOver.GetContext(typeof(UltraGridColumn), true) as UltraGridColumn; if (ugrOver != null) { dropIndexRow = ugrOver.Index; dropIndexCol = ugrOverCol.Index; //index position of drop zone in grid SelectedCellsCollection SelCells; //get the dragged cell which are to be dragged to another position in the grid SelCells = (SelectedCellsCollection)e.Data.GetData(typeof(SelectedCellsCollection)); ultraGrid1.Rows[dropIndexRow].Cells[dropIndexCol].Value = SelCells[0].Value; } }
Sample
Hi Laurent,
You can download the example on the top of the page and upgrade it to the NetAdvantage version that you are using.
Magued
Do you have an example ? because when i click on a cell, i'am in edit mode. I can't drag cell to another localization on the grid.
Laurent
