I got the copy and paste to work great on the wingrid. The one thing that is bugging me is that when I select a column or two and do a copy, it doesn't copy all the rows for that column. It just selects all the columns for the active row i'm in. I tried to have it loop through all the selected column rows on copy but that is really slow. Is there any other way to do this?
Just saw this post: http://forums.infragistics.com/forums/p/29915/148748.aspx#148748 which, rather lamely, excuses the issue. I will have to workaround the problem.
If I understand the original post, I am experiencing the same problem. If I click a grid column header and then copy, when I paste to Excel (or anywhere else), I get the contents of every cell in the first row of the wingrid (which appears to be the active row). I am using 2010.1 - is this still a problem or has it been resolved or is there a workaround/am I doing something incorrect?
Dave
You should Submit an incident to Infragistics Developer Support so they can check it out.
