2732
Performance issue with WinGrid & EditorWithCombo & IDataErrorInfo
I'm trying to implement row/cell errors using IDataErrorInfo and I'm encountering some performance issues.
The performance problem occurs on a column containing an EditorWithCombo with DropDownValidate style.
I've set the column to be required (UltraGrid1OnBeforeExitEditMode event), and when I empty the value of the combobox (= select no value) it takes a really long time before the error is displayed. This compared to the string column which works immediately.
In attachment you will find an example solution. The CompanyEntity.CountryID property is displayed as a dropdown containing the specific countries.
I expect the problem occurs because the country name (string) is attempted to be put in the CountryID field (integer).
You can reproduce the problem by starting the application, emptying one of the row's countryID column and then clicking on another row.
Any help on how to avoid this problem would be appreciated.
Kind regards,
Michael
PS: Version 12.1.2054
WindowsFormsApplication6.zip
