I created a static Appearence that i use for every cell i want to desactivate.
The probleme is that when i close my UltraGrid, the static apperance still reference the desactivated cell and so on my UltraDataRow wich is pretty annoying.
The memory profiler i used make me believe that the appearence still listen to SubObjectPropChangeEventHandler even after the row is closed.
Could you please tell me if it's a bug or if i'm doing something wrong ?
Thanks,Xavier
Hello Xavier,
I am still following this thread. Could you please visit the link below and let us know if you experience the same issue.
http://ko.infragistics.com/community/forums/p/80783/407907.aspx#407907
I am looking forward to hearing from you.
Please do not hesitate to contact us if you still have any other questions with this matter.
Hi Xavier,
This seems very similar to the issue reported here. The issue is currently written up for developer review.
Just to be sure, could you provide a small sample project demonstrating the issue? That way we can make sure that we investigate both cases.
Thank you for posting in the Infragistics forums.
You could check our WinGrid performance guide on the link below, and espacialy the section "Re-using Appearances".
http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.2/CLR2.0/html/WinGrid_Memory_Usage.html
Please fell free to let us know if you still have any other questions with this matter.
