I need to translate some strings that appears on WinGrids all over my Aplication.
The strings are:
- Drag a column header here to groupo by the column;
- item (WinGrid Groups);
- items (WinGrid Groups);
- Click to toggle sort direction.
Can I set this strings?
Thank you in advance.
Beste regards,
Maria
Hi Maria,
If you mean on the GroupByRows, then that's even easier. You don't need the resource customizer for that, you can do it using the GroupByRowDescriptionMask property. There are code examples here:
GroupByRowDescriptionMask Property
Thank you!
I'm not sure how can I translate LDR_Layout_mask. Can you give a example? I want to translate the string "item" and "items".
Best regards,
These links will tell you how to localize any of the strings in the WinForms controls:
Customizing Assembly Resource Strings
