245
AutoCompleteMode=Suggest on WinGrid
I'm using Infragistics 10.3.  I have an UltraWinGrid with a column for customer code.  I have attached an UltraDropDown to the ValueList property of that column.
The UltraDropDown's data source is a DataTable with two columns -- one for customer code, and one for customer name.  I've set the ValueMember to the customer code, and the DisplayMember to the customer name.
This all seems to work fine -- I can click the drop down in the customer code column on the grid and see the list of customers.
But I would like for the user, when adding a new row, to be able to start typing the customer name, and get a list of autocomplete suggestions.  I've tried setting the AutoCompleteMode property of the column on the grid to AutoCompleteMode.Suggest, but it doesn't seem to do anything, and I'm not sure why.  Are there other properties that need to be set for the autocomplete to kick in?
Thanks for any help,
Mike
