115
UltraGrid Delete Key Processing
When user clicks on a grid header and presses the Delete key, I need to intercept that key press:
* If (selected) row is one that should not be deleted, terminate processing the delete key.
* else allow built-in Infragistics grid row delete processing to handle deleting the row.
Being new to Infragistics, I'm not sure:
1) how to set-up intercepting the Delete key press.
    I tried select the grid in VisualStudio in the designer and entered the name of a KeyUp handing routine, but it isn't invoked. Do I need to select something else?
    I tried entering names for KeyDown and KeyPress, but now I'm getting the error regarding 'MdiChildFormBase_Fill_Panel' - see below.
2) How do I:
   * Terminate Delete processing?
   *  Allow Infratistics built-in processing to actually delete the row?
ALSO, how do I prevent the VS error "The variable 'MdiChildFormBase_Fill_Panel' is either undeclared or was never assigned. ". I get this fairly frequently. The designer generated 'MdiChildFormBase_Fill_Panel'. When VS complains about this, it no longer displays the design view. I'm using VS 2012 and Infragistics 2010.3. I know there's a 2012.1 version, but my department is using 2010.
Daryl
