I'm using an isl file and I can't get the horizontal grid row borders to show up. I've been trying to manipulate the GridRow border properties in the App Stylist but to no avail. Another issue is that when hot tracking rows, certain cells, I believe that use value lists but are display only, show a black left cell border only when it's hot tracked. Need help. Thanks.
Ron
Okay, that fixed it. Thanks.
Ron,
Thank you for your attachment. It seems that you might need to set "Alpha" to "# UseAlphaLevel", this is below the border colors.
Your simple file works; my attachment is based on Windows 7 theme and doesn't work. Can you tell me what needs to be changed? Thank you.
Hello Ron,
I tried this and it works fine. I have attached a screenshot and an isl file showing it. Please take a look at the archive and let me know if you have any other questions.
I've resolved the hot tracked cell border but still can't get row borders to show.
