130
Custom ToolTip on UltraGridCell
I would like to customize the appearance of a ToolTip used on an UltraGridCell object.
Currently, I access the tooltip through the ToolTipText property like so:
 UltraGridCell cell = e.Element.GetContext(typeof(UltraGridCell)) as UltraGridCell;
 cell.ToolTipText = itemDesc;
How do I access the ToolTip object so I can change the appearance (such as changing the BackColor, BorderColor, FontData, etc)?
OR, it would be great if I could use the UltraToolTipManager and use SetUltraToolTip() method on the UltraGridCell, but I have not found an easy way to do this.
Hope you can help.
  • 29045
    Verified Answer
    Hello QualicomT,
    Please see my attached sample.
    To customize the appearance of the ToolTip foreach UltraGridCell, please use the MouseEnterElement event and handle it like so.
    You can also use a creation filter that I provided, but it is optional.
    private
    void ultraGrid1_MouseEnterElement(object sender, UIElementEventArgs e)
    if (e.Element is CellUIElement)
    info.ToolTipText = ((
    CellUIElement)e.Element.GetAncestor(typeof(CellUIElement))).Cell.Text;
    ultraToolTipManager1.DisplayStyle = ToolTipDisplayStyle.BalloonTip;
    ultraToolTipManager1.SetUltraToolTip(ultraGrid1, info);
    ultraToolTipManager1.ShowToolTip(ultraGrid1, Cursor.Position);
    ultraToolTipManager1.Appearance.ForeColor = Color.White;
    ultraToolTipManager1.Appearance.BackColor = Color.Black;
    ultraToolTipManager1.Appearance.BorderColor = Color.Red;
    Please let me know if you have any additional questions.
    CustomToolTip119702.zip
  • 469350
    What event is this code in? I don't think you can do it where you're doing it. In order to change the appearance of the grid's Built-in tooltips, you would need a CreationFilter to access the ToolTipInfo on the UIElement.
    Your idea of simply using the UltraToolTipManager is a better one, in my opinion. And there is a sample demonstrating how to do that which is installed with NetAdvantage (assuming you chose to install the samples).
    It will be in a folder something like:
    ...\2013.2\Samples\Misc\CS\ToolTipManager\ToolTips with Context CS
